Clutch swap question
jminor1
Canada.
I have an Srx w a bad primary and have a clutch off a 97 vmax to replace it with, is there any issues w using an 8ax clutch in place of the 8cr a's long a's the internals are swapped out?
I went thru the same thing last year, I was told it would work. My replacement clutch was off a 99 sxr thou, never looked at casting #'s. Has been fine. Somebody will chime in here who will know.
Tony figured so but thought I would check, hope you are well been meaning to check in with you at some point
