MikeSr
Are all the front heat exchangers the same from 1998 to 2002 on the SRX 700? thanks.
I don't think the 98's came with them so Yamaha sold some aluminum ones with a pin on the top that fit into a hole and then gets riveted on the bottom. That way they could be installed without removing the track. I think 99-02 all cam with steel ones that were riveted on top and bottom.
MikeSr
Hmm. That would explain why I could not locate the part number or illustration for one on the exploded view of a 98.
MikeSr
Can't find one in the exploded view for a 99 either.
Here you go. I just sold a set just like this. This is what you need for a 98.
http://www.ebay.com/itm/nos-Yamaha-...ies&vxp=mtr&hash=item19c934b9cf#ht_500wt_1180
I think he is looking for a heat exchanger and not protectors????? If that is the way I am reading it...MikeSr said:Are all the front heat exchangers the same from 1998 to 2002 on the SRX 700? thanks.
they start to put the protector on 2000 and up
MikeSr
The situation is I am about to buy a front heat exchanger from a 99, and I have a 2000. Wondering if the 99 and 00 model year are the same part. thanks guys.
they are the same, the first few years they were not listed as a separate part number, it came with a frame.
I have one off ready to ship out if you need one, can send tomorrow usmail priority, including rivets to do the job correctly.
Sxr700Bandit said:I think he is looking for a heat exchanger and not protectors????? If that is the way I am reading it...
Yup! You're right. I guess I should take more time reading the posts.
MikeSr
Be the Viper, you have a private message
Yooper Dooper
I'm in the processes of swapping mine out right now. I am installing a 1 in. hacksaw track on my 02 SRX and the front heat exchanger protectors that are on there now are 1 in. thick and the new track will rub. Bender has them and they are just a tad over 3/4 in. I think they are all the same for the SRX 98-02 according to Bender.
MikeSr
Does anyone have a front heat exchanger for a 700 SRX that is just collecting dust?
4xpuller
I have one from a 98 SRX 600. I'm pretty sure they are the same but I don't know for sure. If you're interested I can pull it out of the chassis and verify the condition. But I believe it looked really nice. $75.00 shipped.
