SRX Oil pump cable
coreysask
Balgonie
Website
corey.cabler.com
More assistance needed.
Gears fixed...but...decided since it was in the garage to clean the airbox and give the carb a spray...done...but
The oil cable popped when I was putting the air box back together. The line is completely slack. I took the airbox back out to look easier and I see the damn thing is behind the bottom on the motor.
What's the easiest way of reattaching this cable?
Thanks,
Corey
corey@cabler.com
Oil pump cable
If the end has come off the cable on the pump then you are going to have to at the very least get the engine tilted far enough ahead so you can attach a new cable to the lever on the pump.With enough patience and nimble hands you should be able to change the cable without taking the engine out all together but it is pretty tight quarters in there.
