mattyg1405
running a 14" phazer track? track clip ?
anyone ever run a 14" wide track on an srx or viper?
im going threw my sled (motor,bearings,etc>) and dont ant to spend too much on a track i found a couple used phazer tracks would i be giving anything up to a 15" track?
any issues ?
thanks in advance guys...
any issues ?
extremelyfastmax4
lighter track more speed f7 cats run 14 inch track
snoprokidf6
firecat's run a 13.5 wide track. you may sacrifice some traction but you will see higher top speeds, i've been debating on doing this or not, very light weight, probably a good touring track for high distance riders
dmax66
Are the slide rails the same distance apart on the skinny tracks?
snoprokidf6
yes they are, a lot of lake guys run these tracks because they literally weigh nothing, if you can stud them enough for ice and get traction with 150+ hp they make for a great lake/trail track. in any other type if use say off trail or loose snow conditions they don't offer much of anything
mattyg1405
im gonna run it loaded with 144 chisels.
now lets hope it isnt too narrow for the bogies
your talking half inch on both sides lost... ittle be tight. make sure you alighn it well. and another question is the skid the same width as a srx / viper on the phazer? may run into issues with the cogs alighning propery in the skid?mattyg1405 said:im gonna run it loaded with 144 chisels.
mattyg1405
i assume they are all the same width, my engine builder said it would work, im taking his word.
now the next question is track clips, i should i clip every window?
the track i want only has clip every third with no guides.
should i add the clips with guides to all the other windows ? or every other?
anyone have a clip tool close to CT?
mattyg1405
anyone know which track clips i need ?
snoprokidf6
akrievins
If you stick to lakes and trails, why would all riders not want to go to this kind of track? First I've heard of this, and wow, for more top end, this seems like a great option!
sideshowBob
There were many reasons the 2003 F7 cats were as quick and fast as they were[although I hate to admit it] their 13.5 "x 128" track was no small part of their formula. These 14" tracks should work well for descent top speed.
One of the advantages of our old SRXs + Vipers is that they are dureable and last long so, for some of us, they have become the "hot rods" of the snowmobiles. We can take what worked on other brands and adapt them to our sleds. This works great to have a personalized great performing reliable sled.
JM.02c
JM.02c
pro116
Lifetime VIP Member
You will have no issues.I have ran that track on a few sleds.
mattyg1405
awesome thank you guys!!!
