Hi !
I'm want to do some kind of seat riser on a Viper Mountain ( 2004 ).
I think the seating position is way to low for my liking.
If anyone has any ideas or images of a Viper with higher seat it would be great if you could post them.
One thread where it was fabricated from aluminum looked pretty good.
http://www.totallyamaha.net/forums/showthread.php?t=83058&highlight=Seat+riser
Another place is in the Tech Section under "Misc" near the bottom of the page.
Also you could do a search by clicking on the second thread of the SRX/Viper forum and then click on the blue highlighted area for searching.
Hope that helps.
Hope that helps.
Im in the process of making one out of foam insulation board. lot less time to fab up in my opinion.
Here is a couple of Photos of a BOSS seat on our Viper, note we still utilized the Viper dual bulb tail light. Snow flap not yet installed. This is on a 136 extension sled.
This is what I did. Works great! When people say this is the best mod for a viper they are not exaggerating.
http://www.totallyamaha.net/forums/showthread.php?t=70866&highlight=Warts
Here is what I did. I had my grandpa make it eos me he has done upholstry work all his life. WE used the stock seat frame and used a special lightweight foam ,its like styro foam. then put 2 inches of regular foam on top for comfort.
http://www.totallyamaha.net/forums/showthread.php?t=82613
Check it out if you want better pictures of the seat let me know.
YZViper366 said:If you want better pictures of the seat let me know.
Yes please !
Post some nice close up pictures on the seat from different angles.
RZ - Nice machine! Like the mods.
At first I elevated the original seat and that worked out ok but I finally decided that fabricating a whole new seat would be more rewarding.
http://www.totallyamaha.net/forums/showthread.php?t=73614
Thanx guys...Keep the ideas and pictures coming !
