making rear tranfer limiter straps?
coryv4
Michigan
i talked to mpi about there transfer enhancement kit and they said they dont make one for the short travel suspension he said i can easly make my own i have to put a strap on my rear suspension arm so it doesnt fold has anyone made there own if so can you show me a thread or give me a picture of your setup?
Use belting from a hay baler. Cut into strips and drill holes in at to accomplish what you need. Been using it for limiter straps for years on various suspensions when the stock straps wear out or whatever.
Mysledblows said:
Used belting from a hay baler. Cut into strips and drill holes in at to accomplish what you need. Been using it for limiter straps for years on various suspensions when the stock straps wear out or whatever.
do you have a picture i tried searching this with no results
thanks.
Mysledblows said:
Not of a rear one. Don't have any proaction suspensions any more. Switched to aftermarkets.
oh well hopfully i can get this to work i love carrying the skis. what bolts do i grind off so it doesnt get stuck i read your post on this but didnt quit catch what you were saying. and what did you mount the strap to?
I just got a kit from Rich. I know how to install it, I just don't know what gives the most weight transfer? Using the holes on the straps that make the straps loose?
thanks
