i put a 2003 viper rear skid frame on my 02 srx cant get track down was told need to get front drop brackets does anyone have a set to sell or know where i can get them
if flipping your stockers upside down while switching sides doeasnt work, hauck used to sell them. i have a set on my 98, still have the install instructions, no part number.
drop brackets
called them they dont carry them any more even if i coulg get dimensions i could fab them
check with forum member "betheviper", at one time i think he was making them, or he could lead you in the right direction.
staggs65
if you can fab your own just measure from a point directly in line with the shocks to the floor then raise the front to where you need it. remeasure from the same spot and the difference is how much you'll need to lower the stock shock mount location on the bracket. shouldn't be hard to do if you have some fab skills.
Did you try flipping the stock ones over and changing sides or are you looking for even more height?
