88 yamaha 570
i was asking about some advice for my sled build, i put an arctic cat ETT rear skid and all around fox shock in my SRX and was talking to a friend the other day and wondered has anyone put this on there SRX? i got some pics of the suspension all installed, i had the shocks all rebuilt, new seals in rear, handlebar adjuster removed, front shaft replaced. rear front shock is not installed yet but when i sit on the sled and lean hard to one side it actually tips over. the motor is not in the sled yet but i don't think its going to make much difference. i think the rear needs to be a little higher but was wondering what you guys think. and does anyone know how much clearance there needs to be between the track and top of the tunnel, im not sure if i have to remove the plastic pieces inside the tunnel.
here is my new brackets from the doner sled
everyone says it looks like its sitting on blocks in this pics but its the actual height of the front end
these springs NEED a blue powder coating if anyone know someone who does it cheap!!
