lightningsxv
Hey guys quick question about a viper stator.. Are they the same as an srx? What, if any years did they change? What's a good used one worth? After doin a quick search I found a few threads about my electrical issue (dimmed headlights, brake lever shutting speedo off) most of the experts can norrow it down to a rub threw or a stator. I'm 90 % sure it it my stator. I noticed a small nick in it last year during my recoil explosion ( long story short use loctite!!) lol any way need a stator there's lots out there just wondering if one from srx will work, sxr, v max??? Does it have to be from a triple? Thanks guys checking here first always saves a headache later.
I believe they have different outputs. Someone else will chime in here and tell you the real deal. If it is the same I would think it would only be the 01 or 02.
lightningsxv
Ok I wasn't sure hopefully someone knows
srx and viper will show different part numbers but will work in either sled. I have mixed and matched for years. The redhead sled one looks the same but will not work.
lightningsxv
Thankyou BETHEVIPER
