chris700readhead
This is my third year riding sleds and i want a little more out of the 700 . So I'm waiting on a set of Aaen triple pipes too show up that I bought for my sx off MM800. I would like some Carb info and clutching info. The carbs have been rejetted once this year due too doing the air box mod. I also put Reed spacers, boyesen power dual stage reeds, and re-geared it the 22-40. The jets that are in it now are 147.5 on the pto side and 146.3 in the other two. The elavation I run at is about 1050ft and we usually ride with the temps around -5 too 30. Its not often it gets below that but it does happen every now and then.
As for for the clutching goes everything is stock to my knowledge and I don't know anything about changing any part in them let alone setting them up. Any and all help will be appreciated.
Thanks, chris
Thanks, chris
chris700readhead
bump.
