srx questions
It will if you unsnap the plastic bottom or take off the tool kit holder on the srx tunnel. The srx seat uses the tunnel for the trunk bottom. The viper seat has a plastic liner on the bottom. Also will need to swap the tail light connector.
I did not know that about the SRX using the tunnel for the trunk bottom.....that might also explain possibly why I get all the fine snow buildup in the back trunk area.....or is my thinking off basis?
Just unbolt your seat and put some 3M "camper tape" along the sides. It seals up real good.
