So I got my SRX cooler it is a little beat up looking but no leaks...
I am looking to install this in my Viper without getting covered in coolant..
It looks like I have to take off the rear pipe, then replace that with the SRX cooler and tighten the collars.
Are there any other tricks or tips I need to now about?
I am assuming drain some coolant first before I loosen the rear pipe on Viper?
Thanks!
Wildman
Thanks!
Wildman
staggs65
like you said; drain some coolant. I'd then lift the rear, both to make it easier to work on and add a protection margin against getting doused with antifreeze. you have to remove the seat and drill a new hole for the srx cooler bleeder. install, refill and bleed the system
If you want a copy of the mountaining templates and install instructions, pm me a fax # and I will shoot them over to you.
I would appreciate if you could do this to meedunn69 said:If you want a copy of the mountaining templates and install instructions,
super1c
Super Moderator
http://www.totallyamaha.net/forums/showthread.php?t=83653&highlight=heat+exchanger+install
Here ya go, i posted these a while back.
Pictures
Someone having pictures of the SRX cooler instaled in the Viper ??
Experiences with the SRX cooler in the Viper ??
super1c
Super Moderator
They are the same cooler!!! The big one goes in a viper or SRX.
Second post there is a pic of a Srx cooler in my Viper. Its mounted in the tunnel ext but its the same if mounted without an ext.
http://www.totallyamaha.net/forums/showthread.php?t=65925&highlight=stretch
heres a pic of mine installed.. Note.. that i used the oem srx protectors and had to cut the top plastic pieces down a little to make it fit with the protectors. i used bolts to remove the protectors but that is a personal preference. hope this helps. otherwise fits good no major mods neededLasse said:Someone having pictures of the SRX cooler instaled in the Viper ??
