SX700R RIDER
- Nov 13, 2004
I twisted the speedo link off today, took apart to put a new one in , but I have heard a lot of people in this site if this happens to check the bearing. The bearing did not have a gravely feel to it, but the outer race moves side to side a little, but not up and down. I pulled the seal off, it didn't look too bad, just a little dirty, should I clean and repack and put back together or replace the bearing?
SX700R RIDER
- Nov 13, 2004
if i have to replace this bearing can i do it with out pulling the shaft
snowfoxsx
yes you can! there may be a couple of set screws on the shaft on the track side.
hookedonblue
if your spedo failed, you should replace the bearing. trust me.
Thats the first sign of a bad bearing, you can change it pretty easy on the sled, just loosen up the track tension, then remove the 2 set screws in the collar of the bearing, usually while lightly tapping on the collar with a drift punch in the set screw hole pocket, it will come right out. Once out, clean up driveshaft with sandpaper lightly and smear on some antiseize, install your new bearing,set screws, speedo key,speedo housing/cable, tighten track back up- your ready.
SX700R RIDER
- Nov 13, 2004
thanks guys
hookedonblue
no prob, if you need info, heres where ya get it...
yamaholic22
yea it is very easy to change in the sled
