02 sx600r track options
yamajake
North of GR
would a cobra 1.375 fit if tunnel and heat exchange protectors are removed or do i need to stick with a 1.25 ripsaw? I'm not looking to change track drivers or run studs.
Thanks!
Thanks!
It should be fine. My sled had a 1.5" paddle track on it at one point and time and it worked. Stock drivers.
yamajake said:
would a cobra 1.375 fit if tunnel and heat exchange protectors are removed.
Yep.
The cobra is a fine track so long as your not going through corn field stubble or excessive road use/crossing. Ripsaw has a higher durometer and can take more abuse. But the cobra will clean its clock in the POW.
thanks for the info. I try to avoid rough corn fields as much as possible. Most of my riding is 80% groomed trail but would like to get a good bite in the loose snow and powder the other 20% of the time.
