kking32
OK, i know this has been asked before how do you remove the front axle? does the chain case have to come off? i did get the bearing on the speedo side off and the set screws, also already removed the gears and chain, i already did a couple of searches and didn't find much , help please
super1c
Super Moderator
Yes the case has to come off. Here is a great post from the tech section on how to get the track out and goes through removing the case. http://www.totallyamaha.com/snowmobiles/aaTECH/Suspension/replacing_track.htm
kking32
chain case
thanks, that's what i have been looking for, i had a hard time with the emergency brake, it few apart all in pieces, oops, iv'e done a few track replacements before on phazers and enticers etc, but never on the SRX
well then at least your swearing will be down some on this removal then.Some experience is better then no experience .....
