what is the world record for the horsepower of a Phazer 480?
Vmax540
485cc Check Dynotech articles ?
Yamaha Nutz
80 to 85 hp is pretty easy to get ....................I am working on hitting over 100 hp with the new build but i am sure it has been done already
Yamaha Nutz said:80 to 85 hp is pretty easy to get ....................I am working on hitting over 100 hp with the new build but i am sure it has been done already
do you have any pictures?
what have you done to the engine, big bore and homemade pips?
Yamaha Nutz
nothing really started yet ..................84 chassis with enticer long track 136 track and skid hand built twin pipes 44mm carbs ............motor i will be using is one of my old race engines ..........cranks was new last year but top end needs going through so i will start with that motor as the porting can be expanded with a lot less work since in needs to be bored again it will get 1.5 mm over wiseco's and the heads reworked some more if it will not hit the 100 hp mark naturally i guess it will have to get a shot of NOS but that is the last thing i want to do as i get closer to the build i will post pics right now motor is apart and double checking all of my new porting specs to make sure it will hold together for more than a few races
I know when iantomasi first started racing they won quite a few races with a hopped up phaser. Flav had one rookie of the year on that very sled aswell. They likely were around the 90-100 hp area. If not a bit more.
Yamaha Nutz
phazerguy said:Mine dynoed at 89hp
Yep i was standing right there in my shop when she spit out the sheets just could not remeber what it pulled wish we had a little more water volume to hold the srx's ............damn this barely held the 433 gpx we will have to make a trip in spring and get them back on the dyno at his place where the whole set up is
Nutz
