ErikBerg
Hi!
I would like lower engagement rpm in my MountainMax 700. Std is 4500 rpm.
I would like 3500 rpm if possible, in order to run more quietly in the neighbourhood.
* Am I going to loose a lot of power in the engagement? (Guess I will...)
* Which primary spring should I use?
At the moment I have the standard spring, Yellow-White-Yellow.
* Do I have to make other changes, i.e. weight rivets?
Thanks!
/ Erik
Thanks!
/ Erik
