Can any one please help me out? I have a vmax sx 600 that needs a top end.
The burnt cylinders part #
8CR00 598cm3 y-1
I have the opportunity to buy the following part #
8CR00 598CM3 Y-2
Are they the same? Or better question is will they work?
Thanks in advance!
8CR00 598cm3 y-1
8CR00 598CM3 Y-2
Thanks in advance!
I believe the dash # pertains to the cylinder position on the engine with #1 being the PTO side cylinder. I am not sure about the cooling ports and whether they are different from cylinder to cylinder.
9801srx
the 8cr00 is the only number that matters . y-1 and y-2 are just casting numbers. as long as its 8cr00 your good to go.
Thanks. Very much appreciated.
