cam19aro86
I recently bought a SRX 600 and 700 with my step dad and am in the process of getting them ready for the winter. I replaced and cleaned the power valves on the 700 and adjusted the servo with the test port with out an issue. But when I went to the 600 I was suprised to find that there were 3 wires in the little red connector. I tried to power it with the wire in the same location as the 700 with no success. Does anyone know which wire (or both) to power on the 600 to adjust the servo? As it stands I did not get any movement out of the servo on the 600 and with the fear of frying it I figured I had better ask the question first. Any help is much appreciated, THANKS!!
thats a good one i thought they all had olny 2 wires guess not ....you could always start the motor remove the servo cover and idle the engine down below 900 rpm and the servo will turn to the open position ....or you can unplug the harness rite at the servo and power it there to open it
cam19aro86
Thanks YA*AM*A*HEAD, I will have to give that a try.
