2004 viper 6" riser ?
chipnet
Ontario
Has anyone installed a 6"+ riser on their Viper. My son is 6'5" and needs help! any info on risers and cables would be appreciated. Would prefer not to use extentions, Would Mountain Viper cables work???
THANKS
hi
you'll need aftermarket cables,brake line.then what ever style/brand riser.heres some prices,info
long throttle.oil cable's=$60
long brake line=$50
6" you'll have to get a pivot style
6" RSI riser with pivot adapter=$85
6" Powermadd with pivot adapater=$95
5" Rox pivot riser and no pivot adapter needed=$80
s/h to canada=$35
i have 6" rise on my sx. everything is rsi including longer brake, throttle, and oil cables.
I have four inch risers on my 03 Viper. I ordered a Yamaha oil and throttle cable off a 03 mtn viper. Worked great. All i can say is stay away from SPI on the oil and throttle cables. They are junk. Ordered some two years ago because they were cheap. That was a big mistake. First the housing of the throttle cable broke on the first ride with then on and it seemed like the throttle was five times harder to pull once I first put them on. I dont know how Rsi cables are, havent see anyone having problems with them on here so they must be good cables.
I paid 60 for the yamaha oem ones.
richierrich, That's a good one. I always tell my brother that his cat is a POS even though it has been a good sled for him.
I ordered some cables etc.. for my 04 vipers and the RSI ones didn't work. The picture showed exactly what I needed but when it came to me it was two separate cables for the throttle and oil. I think an 04 and newer uses a one into two style cable if you're planning on using the stock handlebar setup.
I had my cables fabricated but I can't remember who did them. I think anything over 3" you will need to change out all the items listed previously.
03 was the last year the vipers had the separate oil and throttle cable. You could have got a 04 mtn viper cable and it should have worked. I think even 3in risers are pushing it, even though people have got them to work. Rerouting some cables over the air box is needed to get 3in risers.
Agpetro - The problem for me was that I have mtn vipers...so since I was going up to 6" I just had it fabricated because I thought it would be way to tight if even possible.
you could of just got the powermadd extension for $30
I could have but I've heard they're not that great! Just what I heard.
