max handle bar riser with stock cables?
coryv4
Michigan
98 sx600 twin what the max handle bar riser i can go with the stock throttle and brake? will bar risers that are pivoted back a little help me pull the skis because i can keep my weight more over the back of the sled? i am going to make my own risers.
I believe 3in is the max with out putting cable extensions on..... I have a 3in on my SXR 700 and i would say any more would deff need extensions
ok thank you.
