multiple fuel pumps
sxviper32
Valparaiso, Indiana
has anyone used multiple fuel pumps on their sleds so that it makes it like its a high output fuel pump? if so, how did you do it? thanks!!!
Why would you need to? the stock pump will flow enuff for about anything you can do to a srx/viper. If you needed more fuel in some case, you would need to add another pulse line port to the case on a seperate cylinder and then stack the pumps, hook to carbs, like I said, the stock will do about anything you could ever do to a sled, maybe short of twin turbo chargers......lol.
