rx1jim
Do the springs in the primary clutch and the driven clutch require replacement with age and mileage? I have 13,000 miles on my 2000 SRX, replacing every part that is not within the wear limits. I've replaced the stock bushings in both clutches with oil-lite bushings, checked all the other components, given every part a good cleaning and polished the surface of the clutch faces on a lathe with 320 grit sandpaper. I may opt to install the inexpensive clutch setup which uses the helix from an RX-1 but the same question would apply to any used springs.
Thanks!
Jim
Thanks!
Jim
for the price of them i would replace them after time .......sure they will change rate with time
YAMMIEGOD3:16
YA THEY DO, WHAT GIVES THE EXTRA LIFE IS TAKING THEM BOTH OFF YOUR SLED IN THE SUMMER. 3:16 (yammie tony)
and hanging a 100 lb weight to them to stretch them out to...YAMMIEGOD3:16 said:YA THEY DO, WHAT GIVES THE EXTRA LIFE IS TAKING THEM BOTH OFF YOUR SLED IN THE SUMMER. 3:16 (yammie tony)
just kidding..but maybe it would help...
YAMMIEGOD3:16
MONSTER, I KNOW IT HELPS OR I WOULD NOT POST IT. 3:16 (yammie tony)
mopar1rules
exactly what i have been doing for years.
yes I know..I remove all my Springs from the clutches in the summer also...just kidding about hanging 100lb weight to them also....
SWEDE
I just replaced my original springs at nearly 12000 miles just because when I rebuilt my clutches this fall.The bushings looked a bit worn, especially in the primary.I'm anxious to try it out with everything freshened up if it ever snows:-p
rx1jim
OK, thanks for the replies. It is easy enough to take the springs out of the clutches at the end of the season. That will become part of my end of season prep routine.
Thanks!!
Thanks!!
