Hello, i have a 77 340 exciter. The main jet is a 135 and the pilot is a 50. Does this sound correct? Also where should my needle clip be? Thanks Rich.
peisnowguy
I can likely help you with this if you are looking for the stock setup. Does it still have the Keihin carb on it and the stock air box?
Hello, i actually sold the 340 motor and installed a 440. Thanks,Rich.
YAMMIEGOD3:16
jetting spec will be different 3:16 (yammie tony)
