base timing on srx
modsrx
canada,qc
what is the timing at iddle on a 2000-up srx 700 .....i ask cause i got the newer ignition system and i wanna make sure i put the pick up coil at the right place ;)!
bluemonster1 said:
set your TPS also..don't forget
already set it ...but i wanna make sure the pickup coil is at good place ..15 btdc does it sounds right ????
bluemonster1 said:
I wouldn't have a clue..don't play around and screw up that motor..ride man ride..it could all be melted by next week..
i doesnt wanna screw it i wanna make sure its set properly ..i know timing does alots of things in 2 stroke .....im sure someone will chime up ;)!
yes if u move it ..it will change went the pick up coil get the signal to fire up ...with the newer ignition u need to weld the case to move the pick up coil closer of the flywheel cause its a smaller flywheel but i did never check it if it was ok ...im sure it is but i want a do a check
bluemonster1 said:
the timing should only be controlled thru the CDI.Where the pu coil is mounted should not really do anything..
yes the cdi controls the timing, but only to a point. if you move the pickup coil either counter clockwise or clockwise around the flywheel, it will also change the timing "statically".
Re 2000+ SRX Timing:
When I was working on my 2002 SRX TPS a few years ago I had a degree wheel on my clutch and a timing light and here's what I found.
At 1800 RPM the timing was 15 degrees BTDC with TPS disconnected
At 1800 RPM the timing was 20 degrees BTDC with TPS connected
Pat Hauck also told me a few years back that the SRX timing was 15 degrees BTDC at 1800 RPM.
Bob
Bob
thnx bob i will make sure its at 15 degree ;)!
yep for sure just to make sure u put it at the exact place .i didnt do it but i will check it this year ..but u will need to change all wiring and cdi and so on
will go on constance bay this year ??? my friend buy a vmax4 im sure he will be open to go get a try on radar
timming
sounds good , i all ready have all 01 electrcal on the sled ,i did not realize you could weld the cases to make it work i also read that a bracket is a option any thoughts
thanks
don't know about bracket but i did prefer to tig weld a new tab and drills new hole for the pick up coil ......if u look to a newer case it will give u a good idea how to do it ....i got a spare case if u wanna see it ..newer
