I am currently riding with a open face helmet and goggles since I wear glasses. I still have my glasses fog up. I was wondering what you guys thought about the no fog mask.
devinzz1
have you tried some anti-fog spray?
orchie18
Some goggles have a foam filter on the bottom and top of the frame. I used duct tape to cover them up, keeps the cold out and, your hot Breath from coming in.
sockeyerun
Test Dummy
No Fog mask will stop mostly all fogging problems except on a real cold day (single digits) if you stop to much. I use a motorcross style helmet with a No Fog mask and Pro Vue prescription goggles with a baclave o the really cold days. I have to wear glasses(contacts are not an option) when I ride and that was the only combo I could find that would allow me to see at all times. Even a No Fog mask and glasses and Full face helmets, heated shields,Fog sprays etc. did nothing. I spent quite a bit of money before I settled on this combo and it works very well for me.
I use a Motocross helmet too. I have tried the no fog spray. It does not work. I have heard this stuff called cat crap works fairly well. Where did you get the prescription goggles??
THe ski doo mountain balaclava works great. THey have a nose flap on the from that directs your breath downwards.
sockeyerun
Test Dummy
A company called pro-vue makes them. I've had mine for probably 8 years, they hold up very well. I highly recommend them, they are really nice people and have replied back quickly on any questions I had. I also have the snap on colored lense system and would also recommend them to. http://www.pro-vue.com/
Thanks sock!! I will check into them.. Has anyone tried the smith or scott goggles that have that fan in them.
Bluemonster2
I will tell you that I have tryed every helmet and goggle combo out there and the only thing that worked for me was the BV2s from skidoo. Havnt fogged up once but they are pricey but well worth it. Goggles suck because they will fog up no matter what and if they dont your glasses will
I ride with a full face helmet and the No Fog mask and my glasses. As long as you get the No Fog mask on properly (sealed around your nose), you won't have issues with any fogging. I've used it from -10°F to 40°F with no issues. I would highly recommend the No Fog mask for anyone who rides with glasses. I'm switching to a modular helmet this year with a built in breath deflector and improved venting. I'll see how that goes but may end up with the NF mask again.
I have two set ups I wear the Yamaha helmet snow force SRX colors with a no fog and works great with glasses. I did remove the installed deflector that came in the helmet on most cold winter days on warm days I wear a fulmer motorcycle helmet with rose colored oakley goggles and my glasses ( sometimes) on warmer days. I enjoy the Fulmer helmet because it's so much lighter and has nice airflow. The rose color is real nice color and makes all bumps, holes visible on normal to bright days. I can ride without my glasses as I can still see o.k. just can't read real good ( OLD AGE )
