srxman06
Need to have my seat repaired but unsure how to take it off. Any ideas?
Lift flap for the trunk, inside on each side there are nuts that need to be removed, Lift and slide seat back diconnect tail light wiring.
2 - 12 mm nuts in trunk - ratchet wrench works best.
srxman06
Thanks..
viperking
a 1/4 in ratchet also works well
Is this the same on an SRX?
yepRacing666 said:Is this the same on an SRX?
FJViper
I find a couple 6" extensions and a universal joint works the best. Just my .02
Cwagner100
Don't mean to steal the thread but I got a srx with the snaps on the front of the seat. Whats a good way to get them off. Mine seem corroded and don't want to pop off.
Cwagner100 said:Don't mean to steal the thread but I got a srx with the snaps on the front of the seat. Whats a good way to get them off. Mine seem corroded and don't want to pop off.
Spray them with a little PB Blaster and let it work for a while. Then use some needle nose pliers or equivalent and try to turn them on the snap. Once they spin back and forth a bit, start pulling while working then back and forth. They should pop eventually.
I use a gasket scraper to help pry the snaps off. Be gentle they are easy to pull through or pull apart.
every time I pull mine the snaps pull thru the material and have to install new ones.So the trick is to pry them off with a screwdriver/flatbar and not tug on the seat material..getting sick and tired of having to re-install new ones every year.They should of made these Velcro fasteners instead,
bluemonster1 said:every time I pull mine the snaps pull thru the material and have to install new ones.So the trick is to pry them off with a screwdriver/flatbar and not tug on the seat material..getting sick and tired of having to re-install new ones every year.They should of made these Velcro fasteners instead,
put some vaseline on them blue they will survive
I put some syn grease on them last time,so will see if that will work moddddddddd!!!!!!!!!!!!!!!!!!!!!!!
