vintage srx
My brothers 01 srx when it sits for more than a month there is excessive oil in the bowls it wont start.If i drain the bowls she will start i'm wondering if it is the check valves leaking or the oil pump.The sled has over 20000 kms.Maybe i should change both.Wondering if anyone else had this problem.vintage srx
I thought about that but my 02 started.Does filing the plungers make that much of a difference.
There are a lot of people that have problems with hard starting and the 1mm seems to make a big improvement. Also to see about too much oil, you should use about 1 quart or so per tank of gas. If you are using more then that check out the oil pump adjustment.
brimgeorge@msn.com
My 02 Viper does the same thing, it's really bad after summer storage. I'm guessing it's the check valves. I'm assuming they are spring loaded checks. I just make sure I start it every once an awhile in the winter. And in the summer it's added engine protection!
