Philsxviper
I just drove my friend viper and he's viper at a perfect sound a midrange compare to mine, mine seems like its cold at midrange, but when i punch it it will go all the way up to 8600 and stay there, its doing this since a long time, but when my friend can tell wich viper is comming down without seeing them you have a idea how much they sound different.
With the air box opened i see some fuel comming out of the mag side cylinder carb when i give it some gas and when i shut it off that the only carb that always smoke into the air box, carb have been cleaned .
I was thinking a broken reed or power valve...
Its rainning today so i will go chek that out if you have any idea let me know..
Exciterfan
Make sure your carb vent line is plugged into the air box properly. If you have it unplugged it will have a bad midrange bog.
Exciterfan
Exciterfan
Philsxviper
cool!!!!
Philsxviper said:I think i found the problem !!!
Yepper.............you should have a good running sled soon, all the stuff your fixin up....lol
