Maheu
I need some help on getting my 40-10 heel clicker set up. Im hoping if anybody knows how i can get a hold of mr viper that would be great. I have a viper with slp triple pipes, 136 inch track inch in half if not its inch in a quater. Has a peak performance billet head. Does have picks over 190 i think. Havnt took time to count them. v- force 3 reeds. spot on on jetting.All right, i have the 02vtp helix from bender i heard that i shouldnt set up my secondary with this helix. I have the red , white blue white springs came with the kit.Anybody with any info could u send me a email . maheu1@ymail.com really appreciate it. thanks guys
Heel-bolt with 5 washers, 1 lock washer
center of weight- long bolt with 1 washer
tip- empty
15 or 15.6mm rollers( you need these!)-stock viper is 14.5mm
red primary spring
green yamaha secondary spring and a helix like 50-40,50/42 set twist at 80
the helix you have has too steep of a finish angle on it and wont work good with h/c in my opinion. report back rpm, your looking for 8900rpm with those pipes. You may be able to add a touch of tip weight but try it first.
tip- empty
red primary spring
Maheu
Where could I find the helix , green spring and the15 mm rollers
Helix
I've got a 49/41 helix I'll sell you for $35 shipped.
Madmatt
Madmatt
Madmatt said:I've got a 49/41 helix I'll sell you for $35 shipped.
Madmatt
Maheu, There you go.... that helix will work just fine and your not going to get a better deal or deal with a nicer person then Matt, trust me.
green sec spring is available right thru your yamaha dealer under part number 90508-556A2-00
rollers you can buy new but expensive, or post a wanted ad in the classified section here, someone will likely give you a good deal on a set. srx uses a set of 15.6mm rollers so that makes them easy to find.
Maheu
Thanks Matt you want me to send the money . Pay pal let me know bud
