motorhead327
I just performed the 5.35" wheel upgrade (all 6) and installed the 7.5" rear wheels. New hyfax were installed along with the marginal snow wheels. The back axle is all the forward and only have about an inch or so of hang when pulling at a med pressure by hand. Is this normal with this setup or is the marginal wheels too much? I just dont want to stress anything out. I'm hoping it will settle in!!
motorhead327
The middle shock is set to 0 preload and the rear shock nut is tightened about 19mm down on the threads. The rear has alot of sag, just wonder if I should tighten the rear shock up more. Thanks
if you can pull it down an inch your good, run it!
I like mine to sag in the middle a little bit when off the ground
Argento102
mrviper700 said:if you can pull it down an inch your good, run it!
I run mine 1.5/1.75"...
that's not what she saidtomseal6 said:I like mine to sag in the middle a little bit when off the ground
you can always take a dremel and make the slot a little longer,that is what I did for more adjustment.
SHAMARKEN
my ripsaw 1.25" with 8 Tooth driver as to be almost banjo tight so it won't ratchet and I do have Rev idler's on it.....
motorhead327
Alright then guys, sounds good to me. Just didnt want to wear out the new hyfax super fast, but thats what the oversize wheels prevent.
What should I do about the rear end sag? I remember reading on here about the sag should be 1/3 of the travel? Does that sound right.
