rodny51082
on the vipers base gasket i noticed that the three cut outs for the water jacket in the front of the motor are all different sizes. when i replaced it i put it back as it came out,with the larger one to the far left hand side(mag). but now i am wondering after looking at micro fisch on a parts site if i put it in right or not or does it even matter. i hope i dont have to take it apart again. some help on this would be much appreciated.
most base gaskets have a notch on them with will identify which way there are flipped and pointing towards mag side.If I remember correctly I had am issue with my base gasket and there was a v notch and the manual tells you which way to place it.
rodny51082
i dont remember seeing any markings on the base gasket. i ordered another one so i could have a look at it befor i take it apart if need be. the top end has been apart befor by the previous owner thats why i put it back that way.wish i looked into it befor hand. but i also wonder if he had done this for a reason maybe. better cooling for the mag side cylinder maybe. has anyone seen this befor.
rodny51082
i found ther is a tab on the gasket does anyone know what side it goes on mag or pto?
staggs65
going by this thread you have it backwards http://www.totallyamaha.net/forums/showthread.php?t=51963&highlight=opticool
staggs65
tab goes between mag and middle pointed towards the front
rodny51082
yup thats what i found to. hate doing things twice. thanks tho
staggs65
also you can reuse that gasket. no need to order a new one
what.....staggs65 said:also you can reuse that gasket. no need to order a new one
staggs65
bluemonster1 said:what.....put a new in for safety sake.I replaced mine on the 2 rebuilds,didn't want to take a chance.
to each their own but no need to unless it gets bent pulling it off
HAPPY NEW YEAR JEFF
staggs65
lol
HAPPY NEW YEAR DOUG
HAPPY NEW YEAR DOUG
whoa!!! scared me with that.....
