aaronbellmx355
Hey guys, just pulled my carbs apart to clean them and the plastic cups that slide over the main jet are really sloppy, I believe they are suppose to fit snug. Is it a bad idea to leave them out I don't want them to get stuck in the float.
Devilin AblueDress!
I would say bad idea, they are supposed to move around. Or at least all of mine have. The are suppose to keep fuel near the jet when hard accel. cornering, the type of stuff that sloshes the fuel around
once the bowls are back on, it wont move. that is assuming the carbs are upside down when you put the bowls on.
HDYAMAHA84
All my sleds ive had have been like that and theyve never let me down.
aaronbellmx355
Sounds good to me thanks for the info, anyone know what size the fuel line is? 3/16 seems small and 1/4 is a little loose.
I think it's 6mm. May even be 5 but I'm pretty sure it's 6mm.
Devilin AblueDress!
Definately metric, 5-6 not sure which. Problem is good luck finding metric hose locally!
aaronbellmx355
Yea that's what I ran into last year and the line I used turned rock solid in less than a year
staggs65
bite the bullet and buy oem replacement lines
