ErikBerg
Pilot screw MM700: does 1-1/2 turns mean 1.5?
Think I have to lean low speed mixture, machine bogs at 4500-5500 rpm.
taylzee
4500 to 5000rpm would almost be into the pilot circuit. On these carbs the screw I believe you are refering to is a fuel screw and turning it out will richen the circuit. bog is usually a lean condition. I ran mine at 1.75 or 1-3/4 turns out from the seated position.
ErikBerg
Sorry my bad translation, what I mean is it seems to go rich.
taylzee
So are you 1.5 turns out from seated? Also, what size pilot jets? Are the carbs clean?
ErikBerg
Carbs areclean. Pilot jets 45,standard size. Reedspacers.
taylzee
Try giving it a shot of choke when it bogs. If it cleans it up, it's a lean spot. With a carbed motor, most likely be fuel screw or pilot. If nothing has changed since it ran good, I would think a dirty fuel circuit.
What is the compression like?
Any other symptoms?
Any other symptoms?
