help my sled backfires
f150swartz
ontario
i have a 1975ish yamaha something (gp i think) 433 or 440.... when its idling it backfires every so often and has no power while driving it around, hardly wants to move at times... my uncle says its points, they didnt look dirty or tarnished so i just touched then lightly with emry cloth... nothing has changed and the plugs are new, any suggestions? thanks in advance.
its with the points the side that moves to open and close taps agints the point on the condersor it might be called a compasator ill look on the yamaha sight and get a diagram of it if i can
Team Parent Racing said:
I would check timing usually flywheel has rust on it, causing timing to be off.
Myron
The flywheel is behind the pull start right? And it has plastic fins on it? How would i go about checking timing/ cleaning the rust off?
Awesome thanks... what are the things wrapped im wire beside the points?
powervalve01 said:
take some fine sand paper and rub lightly on the outer edge of the flywheel and itll clean it up the timing in ont of those is all in the points
Would you be able to explain or show me a link on setting points?
once u get it apart theres a screw losen to adjust if u need to check it when the points are wide open out a feeler guage in between them if theyre black theyre shot
ok thanks... i havent got to it yet. I will shortly supposed to warm up here its cold in the garage lol
