moss
Will newer Model Yamaha Plastic Ski's fit on my 97 Vmax XT, or I am better to stick with the older GYT Model Ski's with the Aluminum Saddle?
I am looking at picking these up, and I want to make sure they fit before I buy them..
http://ottawa.kijiji.ca/c-cars-vehi...ries-Yamaha-Vmax-skis-1999-W0QQAdIdZ342619808
jboar
They will fit but the front end sits a bit lower than the ones with the aluminum saddle
moss
Thanks, do you know if there are any negatives for steering/darting with the lower front end?jboar said:They will fit but the front end sits a bit lower than the ones with the aluminum saddle
jboar
we put them on my brothers 97 vmax 700 sx and there were was nothing negative that I know of. Huge improvement over stock steel skis
Any update would be better...........but I still run modified stocks......... on the SRX,,,,,, other then that SLP-SLT's on the others..............................
moss
Well my old Steel ski's are done, There are holes in them, and the Loops are now broken off, and with no reverse, its a real B*tch...lolWhammy said:Any update would be better...........but I still run modified stocks......... on the SRX,,,,,, other then that SLP-SLT's on the others..............................
I was looking at Simmons, and the 7" Slydog powder Hounds, for more flotation, but the price is too high for me right now, esp since I am planning to upgrade Sleds to a 4 stroke next year....
eboy024
Short track skis
Do the short track skis pick the front end up a little more? What is the advantage?
jboar
It's not the short track but the aluminum saddles on the older skis. It's not much but it is noticeable when sitting on the sled. I would still probably get the new ones without saddles because of the better keel and lighter weight.
