BigMan76
So my 02 SRX has been eating hyfax; I think a 5th wheel kit used to be available, as an aftermarket Yamaha GYT add-on. Does anyone have any information or part #? I did a quick search of the site and came up with nothing. any help appreciated. Thanks.
They sell em on ebay, called marginal snow wheel kit,about $60.
BigMan76
Cleaned out my in box
Yamaha part #SMA-8CR95-00-00
I went with marginal wheels up front,5.35" idlers and 7.5"rears and added ice scratchers.The hyfax will last a good 3 seasons with that setup.
is this what your looking for.edunn69 said:Yamaha part #SMA-8CR95-00-00
I just bought that exact same kit from pioneer.
So, exactly where do you mount this kit? Are the holes already there or do you need to drill them? I have a 1998 SRX700, Thanks for the help, Tim
I found this part number on Ebay but its different then yours SMA-8FA95-00-00, It this the same or a different kit? Thanks, Tim
essentially the same kit, redesigned for the 4 strokers, blocks to rails are slightly different. either kit will work, 4 or 2 stroke.
You need to drill holes, but they come with instructions. The kit is mounted in the front of the stock idlers on the curve in the rail.
I'm at work right now so can't get to my photobucket or I would send you a pic of mine. Let me know if you want to see and maybe I can do it later tonight.
I found a picture online. Thanks to all of you for the help.
BigMan76
Just ordered one from Port Yamaha
