do i need a new chain?
targa20
saskatchewan
i was thinking about changing the top gear on my viper fro a 21 to a 23t. i know that there are people on here that have probably done it so i am just wondering if i need to buy a new chain. a new chain is over $200 and the gear is $100 so i am not sure if it is worth it just to see what it does. i had an F7 spank me the other day and we cant have this happening. thanks for your help
I am running a 23T top gear with a 38T bottom gear and I am still using the 68L chain. When re-assembling you need to put the chain around the gears first then slide the gears on the shaft. I have only put on 100 milessince doing this, but so far so good.
i have done it before also and had no problems, kinda tight though, i wondered when i did it if i would still be able to get it into reverse but havent had a problem.
thanks i might have to try that. how many link chain do you have for your 24 tooth? or what are you running on the bottom?
