8 tooth drivers
first and most noticable will be the gear reduction. its about a 12% change.
secondly, and this should open for debate, you will loose some efficiency due to a slightly tighter radius at the front of the track. in my opinion, if your dropping driver size to install a taller lug track, your giving up that efficiency anyways.
lastly, your speedo will be off if you dont change the housing over from a mtn sled that was equipped with 8t as oem parts.
