Yamiblue
temp light flashing
if the sled is overheating does the temp light flash or stay on continuosly.
my temp light on occasion starts flashing(no code just a steady continuos flash
thanx...scott
thanx...scott
should stay on steady if overheating,hit the deep snow for a bit and light will go off.
Yamiblue
This Is Just Flashing So I Dont Think It An Overheating Issue
Is it flashing a code at all or just steady?
Yamiblue
Just A Steady Flash No Code
PPS. inc
Check wire connections at plug in the head. It will flash constantly if its a wiring issue. Wiggle the wires at the plug. Or it has rubbed thur somewhere.
I think the code is the lenght of flash and the time between flashes.
http://www.totallyamaha.com/snowmobiles/aaTECH/codes/FaultLocationCodes.htm
