Have a issue with my 1993 exciter
Idles fine for 20 seconds or so then idle picks up and tors comes on
If I shut if off and start it back up idles fine for a bit then does it again
I did clean the carbs
Did I miss something?
Thanks for any help
Thanks for any help
YAMMIEGOD3:16
CHECK THROTTLE CABLE SPEC. TORS IS SENCEING CARB SLIDE STUCK. 3:16 (yammie tony)
You were right
Slide stuck
What should it idle at and how do I adjust it
Slide stuck
YAMMIEGOD3:16
should idle around 1600. what exciter is this. WHAT CARBS 3:16 (yammie tony)
Exciter II le
Mikuni carbs
Mikuni carbs
YAMMIEGOD3:16
ADJUSTMENT SHOULD BE RIGHT AT TOP OF THOSE CARBS. 3:16 (yammie tony)
