I found a set of heelclicker 40-10 weights for a good price I believe the base weight is 45 grams. I am wondering if these will work for my piped viper mountain or will they be to heavy?
THanks
Matt
THanks
Matt
snoprokidf6
heel click suggests you put 4.8g in the shoulder then 3.3 in the tip and use the red spring. this is only for starters. mr.viper should chime in soon
Ok ya I wanna hear what people say before I spend the money and buy them
Used them in my 780 srx for years at elevation
So I should have no problem with them being to heavy at 6000-10000ft?? Or any problem getting the rpm I need for the bender pipes on a mtn viper?
blue800
if they are the ones on ebay they have the wrong spring you will need the red spring
YEs I know Haha
CuttingUp$$$$
I also was wondering if the 47-5 would work on a piped viper or do you need to run the 40-10.
Ttttt
