Electric start ???
mtnmaxman600
Wisconsin
looking at putting electric start on my 1997 MM600 and have a couple of ??? looks like the battery gets mounted on the chaincase? Where is the solenoid for the starter mounted? And is the electrical connections there for the solenoid?
:letitsnow :letitsnow :letitsnow :letitsnow :letitsnow :letitsnow :letitsnow
WE NEED SNOW!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Getting bored need to be riding.
the relay or solenoid attaches to the battery tray. theres two tabs facing rearward and the relay has a rubber sleeve with slots to slide onto the tray tabs.
wires should be there, fuse may not. your looking for a red wire to the fuse and relay and a red w/ white stripe from the relay to the key switch.
Get a service manual for the sled. It has diagrams of everything and you will be glad you did.
I have the wiring schematic for the machine and looked last night found the wires on the schematic but just wanted to know where everything is mounted.
A service manual has drawings of where everything is mounted.
