speed track
00sxrjoe
Maine
How long of studs are you guys running it 9811 camplast speed track. rules say your allowed .750 above lug. So with 1.20in pixx its .67-.65 of inch So should I run them or a shorter stud for less rotating mass.
You check out my video on the build up in the working log section Tony?
NICE MAN. I LOVE THE 700 SX.JUST ROCKETS. HAVE SET-UP THREE NOW THAT AREVERY FAST. THOSE PSI PIPES WE BOUGHT FROM YOU WORK GREAT. 8CA WORK GREAT IN THOSE FOR DRAG RACING. RUN THEM AT AROUND 48 GRAMS WITH THAT 50/40. 3:16 (yammie tony)
For drag racing how many should I run? I went out today and did not hook good at all. It has 192 chisels but they are not sharp. Should I mix pix and chisels? Or should I run all pixs?
All chisels work the best. Need to be sharp though. Only sharpen angle not long flat side.
