09nytro
Would using a wire wheel hurt the power valves to clean them . The carbon was very heavy last year . They look the same this year I think I took the coating off
dont use a wire wheel ....you will destroy the coating ..a razor blade is the best way ..i got a video on how to clean them i am gonna post it and ill throw up a link for you ...
09nytro
Well I f them up then I will have to get new ones . Polaris ones are alittle tougher I used a wire wheel on them all the time . Man what a dumb *** I im . Thanks for the info
They can be recoated!
polairis valves are made from stainless steel ..with no coating on them ....yamaha valves are alumnuim with a special anodized coating ......as far as recoating them yes it can be done but i still have yet to find the coating yamaha uses everything i have tryied so far does not hold up to the abuse these valves go thru ......
here is a link to a video on cleaning power valves http://www.youtube.com/watch?v=tEATrpSNLNo
Intersting, Almost like trying to crack a code. Just a shot in the dark, have you tried Dupont's Teflon spray?YA*AM*A*HEAD said:polairis valves are made from stainless steel ..with no coating on them ....yamaha valves are alumnuim with a special anodized coating ......as far as recoating them yes it can be done but i still have yet to find the coating yamaha uses everything i have tryied so far does not hold up to the abuse these valves go thru ......
phatkid
are they done with just a standard anodizing? if so i think i can help with that
09nytro
Well thanks for the info . I did find some for 100 for all 3 I wonder if reg. Anodiz would work till I get new ones
i have tryird teflon with a cermanic and it olny lasts a season or so ..and i have tryied regular anodizing and no luck there either what ever they use is some tuff stuff still looking for a coating that holds up
kirk700 srx
Got my valves Rich, Another great job!!! I sent ya out 2 more today should be there in 2 weeks LOL Once I get those back i will send ya the last one I have thats not repaired. Kinda sucks man ya working yourself out of a job, Oh well I bet I will find some more kicking around this town. Thanks again Man Keep up the great work!
