Air pods/filters
szano
alberta
Anyone scrap there air box and use filter pods instead ? getting sick of removing it every time i need to get carbs off , plus the foam is getting shot. Was also wondering if jetting changes were needed?
I replaced the foam which was brittle and coming apart almost ready to get sucked into the carb/engine. Some small bits at the intake of the carb already it apeared. Black stuff anyway. I cleaned it all away and used air duct filter mat cut to fit.
as for removing the air box. I doubt you can do that its part of the resonance for the engines peformance and may cause damage if driven long without it.
The Yamaha SXs/MMs have very good airboxes complete with factory supplied cold air intake.
Replacing the airbox on these sleds will put you in a world of hurt with substancial rejetting requirements with no performance improvemnts at all in fact probably a performance loss!
JM.02c
Bob
