i am installing wahl anti ratchet drivers what r the dimension for putting them on the drive shaft. center to center and outside lenghts. i want them centered.
thought i had that written down somewhere but cant seem to find it. heres an easy way to calculate-
lay your existing shaft with drivers on the track with the lugs from the track and the lugs from the oem drivers matched up like it would be in the sled. measure the distance between your track windows center to center. should be between 8 7/8-9 1/8. mark the center on the track and transfer it to the drive shaft with a square.
factoring in the hub diameter of the new drivers along with the c-c, you can equate the location of the new drivers based on hub to shaft end measures.
i have found the antiratchets like to be placed more to the outer edge of the windows vs directly centered. i offset them about 1/8-3/16.
