jonmalick
Just put this one together from many parts. The seller of the motor said that it should run good. Got it all put together and took it out for a spin last night. It idles great, has good throttle response, but it seems to be breaking up a little bit in the mid to upper range. I did a thorough cleaning on the carbs, unhooked the tors as I am having issues with that. Now I am just looking for some direction as what to look for next. Should I clean the carbs again?
A couple of bucks
Approx what RPM does she faulter at?
srxman72
make sure you put the exhaust manifold gasket on correctly, if you did you should see a small tab on the top of the pto corner of the manifold. If its on incorrectly, which will block exhaust flow, the tab will be on the bottom of the mag cylinder.
jonmalick
I didnt even take notice. I will check out approximately what RPM tonight.
that is funny but not really.I did that exact thing after rebuilding my 600.Had to remove and turn everything the right side up...srxman72 said:make sure you put the exhaust manifold gasket on correctly, if you did you should see a small tab on the top of the pto corner of the manifold. If its on incorrectly, which will block exhaust flow, the tab will be on the bottom of the mag cylinder.
nytrodave
plug wire caps
jonmalick
Ok, flipped the exhaust gasket. It is still breaking up when I hit around 7,500-8,000 rpm. My meter doesnt go down low enough to check the ohms on the plugs.
rx1jim
Have you tried a different set of spark plugs?
When you cleaned the carbs did you remove the needle and seats to clean the fine filter screen over the top of the needle body?
jonmalick
I didnt see a screen & I dont see it in my manual. Where exactly is it located & how easy is it to get to?
