KZOOVIPER
I need advice on changing the seals (or I guess you could call them O rings) on my power valves, 2002 Viper. It is blowing oil all over the place, and I am assuming it is the seal. Is it as easy as unbolting the housing (4 screws), remove the valve from the cable, and then remove the old seal? Can I remove the seal from the cylinder side of the housing, or do I have to press it out from the other side of the housing? If any one has any other ideas as to what would be making them leak please let me know.
Thanks for any tips
KZOOVIPER
Thanks for any tips
KZOOVIPER
