HDYAMAHA84
when my srx 600 gets up to 8500-9000 rpms the temp light flashes 3 times. i believe its tellin me a code. any ideas what it means? any help would be appreciated!
1.) you need to add weight to clutch at 9000rpm your losing alot of power, need to be 8500rpm tops.
2.) your 3 flash code is for start up to tell you the system is working correctly, you might not see it but the closet code is a code 4 and would be the water temp sensor in the coolant rail.
add: see if you can count the flashes agin, they are either short flashes or longer duration, this is what sperates the code sequence.
HDYAMAHA84
So it shouldnt be able to reach 9000 rpms? Sorry i prolly sound stupid but im trying to learn all this performance stuff lol it may have been 4? there not fast flashes.. it only does it when i run wide open at them rpms
